03-16-2012 06:12 AM
I have a RV042 and have set it up for VPN Client access using the QuickVPN client to connect my remote users. I discovered today that I cannot have two users connect in at the same time. Both users are in the same remote office. They can connect individually with no problem but if one is connected and the other tries connect also the second user gets a message the gateway is not responding. They are both running WinXPPRo SP3. Any help is greatly appreciated.
03-16-2012 10:49 AM
Hello Tod,
Thank you for using the community forum.
Are they using the same user name?
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
03-16-2012 01:48 PM
They are two different users and logins.
03-16-2012 11:19 AM
Were your QuickVPN clients behind a firewall router of some sort? For multiple QuickVPN clients to be able to connect to the remote RV042 at the same time, the local firewall router must have VPN Passthrough correctly implemented. You could try using a RV042 as the firewall router for your QuickVPN clients and you should be able to maintain 2 tunnels at the same time to the remote RV042.
03-20-2012 11:50 AM
The two connections are using different logins. Also I looked at my router on the end where the two computers are and don't see anything about VPN passthrough. It's a wireless router I got from Monoprice. Just a basic wireless router. Any other ideas?
Thanks.
