RV042 VPN Connection problem
nova505llc
I have 2 offices that are connected together through 2 of these VPN routers.  Both routers are online and connected to each other however I am having problems seeing PC's on each network.  For example, from site 1, I can ping the VPN router IP of 192.168.50.2 but cannot ping any PC's on the 192.168.50.x network.  And vice versa.  However from the site 1 VPN router itself in the management console I can ping all PC's on the 192.168.50.x network.
Connection:
Site 1
Router device IP 192.168.1.2
From a PC on this side I can only ping site # 2's router.  No other PC will ping
In the management console of this router I can ping every PC at site #2
Site 2
Router device IP 192.168.50.2
From a PC on this side I can only ping site # 1's router.  No other PC will ping
Hard to explain, hope it makes sense.  Any help is greatly appreciated!
nova505llc
As a test, I created a PPTP account in the site 1 router and when I am on a PC at site 2 and connect to the router using PPTP I can ping all PC's on that network.
