RV082 cascading
ddecoursey
Can you hang another swtich off the LAN ports ?
the RV082  may just be a couple ports shy of what I  need as fars as port density goes  so  Iwas comtemplating hanging an small HP procurve 10/100  8 port switch off one of the LAN ports .....will that work ?
thanks ddecoursey@eriecountygov.org
jasbryan
Level 6
Level 6
ddecoursey,
Yes: you can hang another switch off the RV0xx router. As long as the HP switch is in layer 2 without any vlans created no special configuration needed either. Just plug & play.
Hope this helps,
Jasbryan
