rv082 issue with switch
casualcat99
I have an rv082 that has a 24 port switch, a wap, a voip and the server attached to it.  The switch was a new add about a year ago with no problems until 3 days ago. After some troubleshooting, the server, wap and voip work fine until I plug the switch in it makes the router unreachable.  Any ideas would be great.
mpyhala
Level 7
Level 7
casualcat99,
What type of switch are you using?
Is it managed or unmanaged?
If you connect 2 PCs to the switch with static IPs, can they ping each other?
- Marty
