03-25-2011 09:44 AM
I have RV082 in many locations and it is working fine.
One location I just starting to have problem with packet lose (50 to 60 %)
I ping between two location which i am having problem.
Gateway to Gateway shows no lose on packet (reply with 20ms avg.)
but router to router will lose packet 50 to 60 %
if get any reply it would be around 100 ms to 900 ms
anyone knows what could cause this problem?
Solved! Go to Solution.
03-25-2011 07:49 PM
MKYENT2000,
I suspect that the issue is not router related based on what you have told me so far. The way to know for certain is to change one of the routers with a known working one. Try the ping and see if you have the same results.
03-25-2011 01:09 PM
Hi MKYENT2000,
Thank you for posting. I am a little confused about your configuration. When you say router to router do you mean through a VPN tunnel? Please provide more detail about your network.
03-25-2011 02:36 PM
Each Internet Connection has Static IP address
Ex.
Office 1 - RV082
public Ip address 66.66.66.66
subnet 255.255.255.248
gateway 66.66.66.71
lan ip to router 192.168.1.1
Office 2 - RV082
public ip address 77.77.77.77
gateway 77.77.77.82
lan ip to router 192.168.2.1
I am not able to setup VPN due to packet lose
ping from 192.168.2.1 to 66.66.66.71 (no packet lose)
ping from 77.77.77.82 to 66.66.66.71 (no packet lose)
ping from 192.168.2.1 to 66.66.66.66 (packet lose 50% to 58 %)
same goes pinging from other office site
this is DSL with modem is acting as gateway and router behind
Hope I explain myself
thanks for looking into it
03-25-2011 04:44 PM
MKYENT2000,
Thank you for the additional information. I gather that you can ping the gateway of the opposite router no problem but if you ping the static WAN IP of the opposite router you have packet loss. A few questions:
03-25-2011 05:50 PM
I have try MTU to 1492 Manual setting, but no luck
Not sure it is router problem, I am end of wall with this problem
I have turn off all PC and Server from one location and connect only Laptop and having same issue.
Could this be cause by DSL company switch?
if so, how gateway can ping each other without lose packet.
03-25-2011 07:49 PM
MKYENT2000,
03-26-2011 05:56 AM
I have try new working RV082 Router and result is same.
It is just between Office 1 and Office 2, I can access either office from Office 3 , 4, 5, 6 without any problem.
I even shut down all workstations and server at both location and try to ping but result is same.
DSL company cold not find any problem on thier side at either place.
03-26-2011 08:28 AM
Problem is resolved by replacing IP Block assign to my office
I am sure it was in DSL Company side.
Thank you for reading and help
03-26-2011 10:02 AM
MYKENT2000,
Thank you very much for participating in our community. You feedback is much appreciated!
