02-24-2011 08:32 AM
I'm trying to setup a VPN Tunnel between RV082 and WRV200.
The RV082 has an static IP, the WRV200 has a dynamic IP. I have to Dyndns.org in the WRV200.
Does this work?
I have setup the RV082 tunel auth like:
Dynamic IP + email
In the WRV200 I setup the hostname with the username, and the domain with the domain part of domain entered in the RV082
In the RV082 VPN Log I got:
Initial Aggressive Mode message from 11.22.33.44 but no (wildcard) connection has been configured
It seems to be working the IPSEC setup but the RV082 does not accept the connection because of a missmatch in the
Remote Security Gateway Type
parameter in the RV082.
Any help is welcomed, thanks
Oliver
Solved! Go to Solution.
03-08-2011 12:35 PM
Olivers,
Unfortunately, there is nothing that can be done to remedy what you have going on with the tunnels. The only way to stabilize this is to have that dyndns account so when it changes it will update and maintain the tunnel.
03-08-2011 12:35 PM
Olivers,
