ā09-19-2011 08:38 AM
Hi.
I tried to use Migration Utility v 1.2.2.0 with configuration file from older unit having VPN tunnels and application is crashing with windows MFC error(on several computers, so it is not related to PC).
Migration from V2 to V3 of configuration not having VPN tunnels went ok.
I provided to Cisco support configuration file one month ago, but no answer till now.
Best regards,
Catalin Burla
ā09-19-2011 12:37 PM
Which RV082 firmware did you export the config file from? If you have provided your config file to the support agent, you could check with the agent whether they can reproduce the issue. Usually it won't take a month for the agent to get back to you if the steps to reproduce the issue is clear.
ā09-19-2011 03:14 PM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Do you have the Case Number or Name of the agent that you worked with? Could you provide to me the e-mail of the agent that you sent this to? I would like to look into this for you.
If you can, please send to emoyers@cisco.com
Eric Moyers
Cisco Network Support Engineer
CCNA, CCNA-Wireless
1-866-606-1866
ā09-19-2011 04:33 PM
In case you have not seen it, here is the release notes for the migration utility. Please note the known issues on page 2.
http://www.cisco.com/en/US/docs/routers/csbr/rv0xx/release/rv0xxMigrationUtility_rn_v1-0-2-2.pdf
Eric Moyers
ā09-20-2011 02:54 AM
Hi.
Thank you Eric for prompt reply. I have sent you an email with information requested (also with configuration file).
Regarding know issues of migration utility , none is about application fail or crash. I would have no problem if conversion was done having "special characters" replaced.
Best regards,
Catalin Burla
