This is my lan configuration:
RV110W router connects to the internet (PPOE) through WAN
Unmanaged switch #1 connects to lan port of RV110W
6 machines connect to the switch directly
I want to isolate 2 machine from the rest of ther other machines without additional hardware. These machines should not be able to access the RV110 configuration web interface. I heard this is possible by creating a subnet. How would I do that on the RV110w?
Here is the router configuration page demo:
https://www.cisco.com/web/sbtg/gui_mockups/RV110W/default.asp.htm
Are these the correct steps (no additional hardware or cabling):
1) Create another VLAN #2
2) Change both VLAN #1 and VLAN #2 to tagged on Port #1 (exclude the other ports)
3) Goto "LAN Configuration" and put the local IP as 192.168.2.1 for VLAN #2 and then change the subnet mask to 255.255.255.128?
