RV130 problems with remote management!
mw000000111
Beginner
Beginner
We have 2 RV130 routers connecting to sites with IPSec Site to Site.
The remote management on both routers are suddenly not reachable after a week of operation.
Every week the routers need to be restarted in order to get access to the remote management again. I am very dissappointed that this has not been fixed! After all this device is not a consumer grade router and should have these flaws fixed asap.
The routers are running the latest 1.0.2.7 firmware. I have noticed it seems to be too common with the RV series of routers. Does anyone else have this problem and a solution to resolve this?
In general Cisco needs to get a grip because it seems there are too many issues with these routers!
kevinchan
Beginner
Beginner
I have the same issue.. .
I just updated the firmware to 1.0.2.7.  Hopefully that fixes the issue.
which version of firmware are you running?
Kevin
Recognize Your Peers
