RV180 QVPN cannot ping remote lan PCs
FergieMLF
I can use PPTP and access all the PCs on a flat network at a remote site.  I can ping the pcs and connect with netsupport manager.
When I use QVPN I cannot do this.  Why?  I have added custom ports 5405 for NSM and applied ACL put no joy.  I also added PING to ACL but it still doesn't work.
What do I need to do?
janickle
Are you trying to reach the remote PC’s through the IP address or NetBios name?
Thank you,
Jason Nickle
