RV180 ssh and https from WAN?
Hy everybody.
Is there any way to manage the RV180 from the WAN side via https and/or ssh?
Also, is ssh from LAN even available?
Kind regards,
F.
dlatorre
Flavio,
The RV180 only supports remote management over http or https. The Cisco Small Businness Routers do not support ssh or telnet.
You can enable HTTPS and remote management on the LAN interface of the Cisco
RV180/RV180W. If a user connects a PC to the LAN port, web access is then
allowed using secure HTTP (HTTPS).
paolo bevilacqua
Wrong forum, post in "small business - routers". You can move you post using the actions panel on the right.
dlatorre
Flavio,
Hello Daniel,
thanks for your reply.
Many thanks, you confirmed my thoughts :-(
Kind regards,
Flavio.
