I have a client who has 3 locations. The two remote offices each have a RV180 and connect to the primary office location. The two remote offices connect with a RV180 via Gateway Firewall.
The primary RV180 is configured to connect to the following peers Gateway.
This set up is working fine. My question is, there are remote USERS that want to connect via VPN from their home PC's. Does that router have the capability to have users connect as well as other RV180 routers?
My guess is that the radio button needs to be toggled from Gateway to VPN Client in the IPSec > Basic VPN Setup menu.
I don't want to break the connection with the other offices, but I need to enable to ability for home users to connect.
Thanks you,
Brian
