09-07-2012 07:38 AM
we've changed our rv042 for a rv180w and now when I try to upload files to my ftp server (vsftpd under centos) it get stuck at 100%.
I've changed my ftp server to proftpd instead of vsftpd and everything's ok.
but vsftpd isn't the problem since i was able to upload with my rv042 without any problems
so i guess there's a problem with the rv180w security.
any help ?
i've already disable stealth mode and it's doing the same thing
also : when i try to upload to the same server but through the vpn tunnel, everything's ok.
So it's really in the rv180w lan->wan routing
thanks
09-07-2012 08:49 AM
Hi Tommy, try to disable everything else on the firewall attacks.
-Tom
Please rate helpful posts
09-07-2012 09:04 AM
i've disabled everythings and it's not working
WAN (Internet) Security Checks
Respond to Ping on WAN (Internet):
Stealth Mode:
Flood:
LAN (Local Network) Security Checks
Block UDP Flood:
ICSA Settings
Block Anonymous ICMP Messages:
Block Fragmented Packets:
Block Multicast Packets:
09-07-2012 09:12 AM
Tommy, run a packet capture on the WAN and LAN of the router under the Admin -> Diagnostics
To create a successful capture-
Repeat this process for the LAN side as well. This will determine if the FTP makes it through the router and when the 100% failure happens, it should show what breaks down. If you need assistance to intrepret the pcaps, call the SBSC to open a case.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
-Tom
09-07-2012 10:34 AM
when it's stuck at 100%, if I check on the server, the file is there and complete,
after 15-20 seconds filezilla tells me if i want to overwrite the file i just sent because it'S trying to resend it.
so the transfert is complete but it can't close it
09-10-2012 07:36 AM
any help?
i've looked at the pcap files and everything's ok in the transfert
09-10-2012 01:16 PM
in the wireshark log everything's ok but it stuck at 150 ok to send data and then i get a timeout,
it can't get to 226 transfert complete
I also get a tcp zerowindow after the 150 ok to send data
02-03-2013 12:23 PM
We've got the same problem. Has there been any resolution?
02-05-2013 09:04 AM
Spent a couple of hours in online chat with no results.
From a mac, the uploads will actually complete, but they take a very long time - ie 40 seconds for a 6 byte file.
From a pc, the uploads won't complete.
If connecting to ftp servers is something you require as part of your business, I STRONGLY recommend staying away from the Cisco RV180W Wireless router.
BTW, in the end the response from support was "well it works on mac, so it must be a windows problem". It does not work on mac, 6 bytes should upload in less than a second, and does on every other router we've ever used. He wasn't interested in that part though.
I'm not sure why I thought that by buying Cisco I'd get a better quality product.
02-15-2013 10:10 AM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
Just saw this post. I don’t think this is something that can be handled efficiently over chat.
Mr. Vallee, did you open a case on this, if so, please let me know the number so I can follow up on it.
If not, and same for you Mr. Browning, please do call in and open a case. One of our Engineers will be glad to assist with this issue.
Eric Moyers .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866 ext 601027
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
*Please rate the Post so other will know when an answer has been found.
02-15-2013 10:28 AM
no didn't open a case
i'm giving up on this router, many many many problems with it
-vpn tunnel dropping packets every 30 sec
-vlan's dhcp not working after a few days
-vsftpd ftp problem.
-when settings QoS for my ip phone, internet stop working for 5-10 sec every 2-3 times a day
no firmware update since nearly 1 year.
edit : to get this router working flawlessy (except the vsftpd problem and Qos problem) I have to reboot it every 3-4 days
switching to fortinet, bye bye cisco and your cheap router.
