rv260 can not disable hardware dmz
7benjamin7
I've tried turning it on but now want to disable it and configure port 8 as something else.
Every time I try, the option is greyed out.
is this a bug in the guy config?
Jo Kern
Hi, i played around and seems to work fine for me. Firmware 1.0.00.15.
Maybe a bug in combination with some other settings on your router.
Or sometimes a browser issue? But if you see no other flaws in the browser most likely not.
ah, i'm foolish. the answer was staring me in the face.
I have a disabled rule in the ACL that references the DMZ interface.
Disabling the rule is not enough. needed to remove the rule, then i can disable the hardware dmz
