03-19-2020 12:51 AM
Hello Everyone.
I have successfully configured OpenVPN server on my router (LAN IP 192.168.0.3). VPN client connection works fine... almost. I am using Split Tunnel, routing client traffic destined to the following subnets through VPN
option in order to access two subnets (LAN) 192.168.0.0 and 192.168.1.0. Open VPN client adds appropriate rules to route packets to those subnets properly (client-side routes):
192.168.0.0 255.255.255.0 10.1.7.1 10.1.7.2 266
192.168.1.0 255.255.255.0 10.1.7.1 10.1.7.2 266
I added the following rule on my main router managing networks 192.168.0.0 and 192.168.1.0
10.7.1.0 192.168.0.3 255.255.255.0 UG 0 0 0 eth0 in order to route traffic to 10.7.1.0 via 192.168.0.3 (RV260)
According to my knowledge, I should add static routes on 192.168.0.3 (RV260) in order to pass packets between the VPN subnet (TUN interface) and those two networks. My issue is that I can't see TUN interface on the interface list. I see only WAN, VLAN1 and USB.
I would appreciate any help greatly. Thanks in advance.
Solved! Go to Solution.
03-24-2020 02:18 AM
03-24-2020 02:18 AM
