RV320 Configuration Issues
jheberling1
So I just purchased a RV320 ....
1 - My LAN IP network is 172.18.x.y/16 -- is there any way to set the RV320's IP address as  172.18.100.235 ?  I could not find it ....
2 - VPN -- I have IPSEC VPN's working between Cisco 2901, 1841, and 1711.  I would like to copy the VPN config section from the "old" routers to the RV320 -- is there a way to get into the RV320's via telnet or ssh ?
3 - When I try to activate an IPSEC VPN the 320 seems to want to make it an SSL VPN.  Im getting message regarding some sort of OAKLEY negotiation.  The messages go away when https is turned off in the firewall settings at which point administration also reverts to http.
Please help !  Im trying to avoid having to return this router.
Juergen
cindy toy
Level 7
Level 7
Hi Juergen,
Since you are within warranty, I suggest you do an online chat with a tech support engineer located here:
https://supportforums.cisco.com/community/netpro/small-business/sbproductwarranty
or you can call tech support and the phone numbers in your area are located here:
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
