RV320; dedicate LAN PC to specific WAN
joemajestee
Is there a way to assign a specific PC on the LAN to use WAN1? We have two WANs and one has a much faster upload than the other and I want a certain user to always connect to the internet that way.
mdobiac
Level 3
Level 3
Hello joemajestee,
Here is something you can try by going under System > Dual WAN, select the WAN you want to edit and in the new window that populates you will see a field called Protocol Binding.
In this field click on 'add' and select all services, the Source start and end IP will be the IP of the PC you want and the destination will be 0.0.0.0 0.0.0.0 and the WAN will be the WAN you want the PC to use.
I haven't tested this but it may do what you want.
Hope this helps.
Michael D.
