02-07-2021 10:33 AM - edited 02-07-2021 11:05 AM
FW: 1.5.1.13
I've found a few posts here where other users have suffered with RV320s which seem to fall over when UPNP is enabled in general firewall settings, but there's never any followup posts.
I'm having the same problems, but need to use UPNP. Grateful for any thoughts here before I throw the RV320 in the bin. Clearly this is an issue with these routers, so I sadly won't be looking at Cisco's range of small business routers if there isn't some fix I'm missing.
Many thanks!!
Log entires just before the crash [some IP addresses masked with xxx]:
2021-02-07, 17:12:13 Kernel kernel: Set: GPIO[5] Value[HI]
2021-02-07, 17:12:13 Kernel upnpd[1883]: AddPortMap: DevUDN: uuid:75802409-bccb-40e7-8e6c-fa095ecce13e ServiceID: urn:upnp-org:serviceId:WANIPConn1 RemoteHost: (null) Prot: TCP ExtPort: 8888 Int: 192.168.3.80.8888
2021-02-07, 17:12:13 Kernel upnpd[1883]: [AddPortMapping]eport:554, proto:TCP, iport:554, ip:192.168.3.80, en:1, desc:DVR_NVR PORT MAP
2021-02-07, 17:12:13 Kernel upnpd[1883]: UPNP Rule is not FULL!!!
2021-02-07, 17:12:13 Kernel upnpd[1883]: AddPortMap: DevUDN: uuid:75802409-bccb-40e7-8e6c-fa095ecce13e ServiceID: urn:upnp-org:serviceId:WANIPConn1 RemoteHost: (null) Prot: TCP ExtPort: 554 Int: 192.168.3.80.554
2021-02-07, 17:12:13 Kernel upnpd[1883]: [AddPortMapping]eport:443, proto:TCP, iport:443, ip:192.168.3.80, en:1, desc:DVR_NVR PORT MAP
2021-02-07, 17:12:13 Kernel upnpd[1883]: AddPortMap: DevUDN: uuid:75802409-bccb-40e7-8e6c-fa095ecce13e ServiceID: urn:upnp-org:serviceId:WANIPConn1 RemoteHost: (null) Prot: TCP ExtPort: 443 Int: 192.168.3.80.443
2021-02-07, 17:12:13 ALLOW TCP 192.168.3.115:49459 -> 17.248.144.110:443 on eth0
2021-02-07, 17:12:19 ALLOW TCP 192.168.3.123:50310 -> 192.168.3.1:443 on eth0
2021-02-07, 17:12:19 ALLOW TCP 192.168.3.123:50313 -> 35.190.242.182:80 on eth0
2021-02-07, 17:12:19 ALLOW TCP 192.168.3.123:50311 -> 23.39.205.44:443 on eth0
2021-02-07, 17:12:19 ALLOW TCP 192.168.3.123:50315 -> 13.32.169.28:443 on eth0
2021-02-07, 17:12:19 ALLOW TCP 192.168.3.123:50323 -> 192.168.3.1:443 on eth0
2021-02-07, 17:12:19 ALLOW TCP 192.168.3.123:50322 -> 192.168.3.1:443 on eth0
2021-02-07, 17:12:19 ALLOW TCP 192.168.3.123:50325 -> 52.8.154.24:443 on eth0
2021-02-07, 17:12:19 ALLOW TCP 192.168.3.123:50326 -> 13.32.169.28:443 on eth0
2021-02-07, 17:12:19 Kernel kernel: wrong ip[0],not_list[0]
2021-02-07, 17:12:19 Kernel kernel: upnp idx=190, ip=192.168.3.80, eport=8888, iport=8888
2021-02-07, 17:12:19 Kernel kernel: upnp idx=48, ip=192.168.3.80, eport=554, iport=554
2021-02-07, 17:12:19 Kernel kernel: upnp idx=193, ip=192.168.3.80, eport=443, iport=443
2021-02-07, 17:12:19 Kernel upnpd[1883]: Shutting down on signal 15...
2021-02-07, 17:12:19 Kernel upnpd[1883]: DeleteAllPortMappings: UpnpNotifyExt(deviceHandle,uuid:75802409-bccb-40e7-8e6c-fa095ecce13e,urn:upnp-org:serviceId:WANIPConn1,propSet) PortMappingNumberOfEntries: 0
2021-02-07, 17:12:19 ALLOW UDP 193.29.14.132:41156 -> xxx.xxx.xxx.xxx:5060 on ppp1
2021-02-07, 17:12:19 Kernel kernel: add new: cnt[20] learn mac[74-3-bd-96-39-b4], ip[192.168.3.114], idx[b4]
2021-02-07, 17:12:19 Kernel kernel: add new: cnt[21] learn mac[a4-83-e7-ab-64-34], ip[192.168.3.109], idx[34]
2021-02-07, 17:12:19 ALLOW TCP 192.241.208.46:56910 -> xxx.xxx.xxx.xxx:80 on ppp1
2021-02-07, 17:12:19 ALLOW UDP 193.29.14.132:34689 -> xxx.xxx.xxx.xxx:5060 on ppp1
2021-02-07, 17:12:19 ALLOW TCP 63.143.61.42:40909 -> xxx.xxx.xxx.xxx:80 on ppp1
2021-02-07, 17:12:19 ALLOW TCP 63.143.61.42:55004 -> xxx.xxx.xxx.xxx:80 on ppp1
2021-02-07, 17:12:19 ALLOW UDP 193.29.14.132:33221 -> xxx.xxx.xxx.xxx:5060 on ppp1
