11-18-2017
12:27 AM
- last edited on
03-25-2019
11:10 PM
by
ciscomoderator
The latest firmware for the RV320 posted Nov 17 as 1.4.2.17. I just downloaded and attempted to update to one of our bench RV320's running 1.4.2.15. After it uploaded to the router, it kicked back a dialog saying bad firmware.
Re-downloading resulted in the same message.
Would someone check to see if there's an error in the .bin build?
THanks
Chet.
Solved! Go to Solution.
01-17-2018 12:06 AM
02-15-2018 07:16 AM
Unfortunately, it hangs every 2-3 hours also on me. The problem is that I reverted to 1.3 and is also hanging few times per day.
Load balance is a mess but hangs also on link backup.
This router is nothing but a junk and Cisco doesn't care about it at all.
