02-14-2014 12:05 PM
I really wish someone would FIX the programming to allow a PPPoE WAN1 type to use a DMZ range in the same subnet. I have gripped about this for years and keep getting ignored. This is prevalent in many of the cisco routers/security appliances and it is annoying. It is in the RV042G (which seems to just be an older version of the 320) and the ISA550 which I have been able to trick it into working.
I just purchased a RV320 thinking it would be fixed and alas it is not. If I could get past the error dialog, I would probably be fine. I have a public /29 block that is routed through a PPPoE connection. The block is in the same subnet, but because the connection is PPPoE, the WAN is programmed to REQUIRE a Static IP on WAN1 to allow a DMZ in the same subnet.
Are there any Cisco Engineers listening that can get this fixed!!!! I - and many others who use this type of connection - would be eternally grateful.
02-14-2014 01:01 PM
DNS Admin,
To make a feature request or report a bug in the Cisco Small Business devices, please open a support case:
www.cisco.com/go/sbsc
Are you unable to use One-to-One NAT for your scenario?
- Marty
02-14-2014 01:10 PM
I have opened several support cases and even corresponded as well as spoke to an engineer. A year has gone by and nothing.
The servers have public addresses so the one-to-one isn't doable. I am running some services that require the server to have a hard-coded public IP
It would be great if there was a SMB device that would allow a public and private segments and route between them to the internet
