For several months, I am trying to correctly configure the client-to-site ssl connection on the rv340 and rv320 routers. I use simple EasyVPN configuration. Regardless of the firmware version on the routers from the CiscoVPNclient application on windows7, I ALWAYS be able to connect correctly. The problem starts when I try to connect to a smartphone.
For the RV320 router I can connect to the smartphone only to the software version v1.3.1.12 For every higher version connection from smartphone is failed.
For the RV340 router, the 1.0.02.9000 firmware was available for a while and I could easily connect to it. Unfortunately, only versions 1.0.01x are now available, in which it is impossible to connect with standard Android or Iphone software.
Please help me what I'm doing wrong?
Can I download RV34x-1.0.02.9000 somewhere?
Klaudiusz
