I am trying without much success to establish an openvpn with a cisco RV325 router with the recent firmware.
Is there a clear step-by-step walk-through on how to do it with a windows / iphone client ?
here is an example log result: Any help would be appreciated.
thanks
Raz
Sun Oct 09 17:13:35 2016 OpenVPN 2.3.12 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Oct 3 2016
Sun Oct 09 17:13:35 2016 Windows version 6.2 (Windows 8 or greater) 64bit
Sun Oct 09 17:13:35 2016 library versions: OpenSSL 1.0.1u 22 Sep 2016, LZO 2.09
Enter Management Password:
Sun Oct 09 17:13:35 2016 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Sun Oct 09 17:13:35 2016 Need hold release from management interface, waiting...
Sun Oct 09 17:13:36 2016 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Sun Oct 09 17:13:36 2016 MANAGEMENT: CMD 'state on'
Sun Oct 09 17:13:36 2016 MANAGEMENT: CMD 'log all on'
Sun Oct 09 17:13:36 2016 MANAGEMENT: CMD 'hold off'
Sun Oct 09 17:13:36 2016 MANAGEMENT: CMD 'hold release'
Sun Oct 09 17:13:44 2016 MANAGEMENT: CMD 'username "Auth" "<<hidden>>"'
Sun Oct 09 17:13:44 2016 MANAGEMENT: CMD 'password [...]'
Sun Oct 09 17:13:44 2016 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sun Oct 09 17:13:45 2016 Socket Buffers: R=[65536->65536] S=[65536->65536]
Sun Oct 09 17:13:45 2016 MANAGEMENT: >STATE:1476022425,RESOLVE,,,
Sun Oct 09 17:13:45 2016 Attempting to establish TCP connection with [AF_INET]XX.XXX.XXX.XXX:1194 [nonblock]
Sun Oct 09 17:13:45 2016 MANAGEMENT: >STATE:1476022425,TCP_CONNECT,,,
Sun Oct 09 17:13:46 2016 TCP connection established with [AF_INET]XX.XX.XX.XX:1194
Sun Oct 09 17:13:46 2016 TCPv4_CLIENT link local: [undef]
Sun Oct 09 17:13:46 2016 TCPv4_CLIENT link remote: [AF_INET]XX.XX.XX.XX:1194
Sun Oct 09 17:13:46 2016 MANAGEMENT: >STATE:1476022426,WAIT,,,
Sun Oct 09 17:13:46 2016 MANAGEMENT: >STATE:1476022426,AUTH,,,
Sun Oct 09 17:13:46 2016 TLS: Initial packet from [AF_INET]XX.XX.XX.XX:1194, sid=8faf7660 a0898659
Sun Oct 09 17:13:46 2016 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Sun Oct 09 17:13:46 2016 VERIFY ERROR: depth=1, error=certificate is not yet valid: CN=00:2a:10:ba:b2:44, OU=RV325, O=Cisco Systems, Inc., L=Irvine, C=US, ST=Califomia
Sun Oct 09 17:13:46 2016 OpenSSL: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
Sun Oct 09 17:13:46 2016 TLS_ERROR: BIO read tls_read_plaintext error
Sun Oct 09 17:13:46 2016 TLS Error: TLS object -> incoming plaintext read error
Sun Oct 09 17:13:46 2016 TLS Error: TLS handshake failed
Sun Oct 09 17:13:46 2016 Fatal TLS error (check_tls_errors_co), restarting
Sun Oct 09 17:13:46 2016 SIGUSR1[soft,tls-error] received, process restarting
Sun Oct 09 17:13:46 2016 MANAGEMENT: >STATE:1476022426,RECONNECTING,tls-error,,
Sun Oct 09 17:13:46 2016 Restart pause, 5 second(s)
Sun Oct 09 17:13:49 2016 SIGTERM[hard,init_instance] received, process exiting
Sun Oct 09 17:13:49 2016 MANAGEMENT: >STATE:1476022429,EXITING,init_instance,,
