04-10-2017 02:32 AM
Is it possible change default port 8443 to 443? SSL VPN does not make sense for us, if does not use standard port.
When I change port to 443 AnyConnect throw error about communication errors with server.
11-02-2017 05:46 AM
01-10-2018 12:51 PM
Same problem for me. I also tried to change the default management port to any other TCP port under "Firewall - Basic Settings - Remote Web Management". Still getting the error "This port is used by Remote Web Management / LAN/VPN Web Management" when I try to set the SSL-VPN Port to TCP443.
It doesn't feel right to configure SSL to use the wrong port as this will just make it more difficult to connect via VPN.
Looks like a bug in the RV340W firmware.
03-31-2020 08:44 AM
Hello!
Meanwhile the bug seems to be fixed. SSL-VPN via TCP443 works now, tested it with release 1.0.03.16.
The only thing to do is change all Ports under Firewall-Basic Settings to other than 443.
Then you can change the SSLVPN-Port to 443.
Best Regards,
Woger
