Showing results forĀ
Search instead forĀ
Did you mean:Ā
RV345 Firmware Update 1.0.01.18 to 1.0.03.20
longbeard
When I purchased this product a few years ago it was mandatory that you applied firmware updates in sequential order. Has this issue been solved? Can I update directly from 1.0.01.18 to 1.0.03.20
marce1000
 - These type of devices usually don't have that kind of dependencies, which this document seems to confirm :
       https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5506-upgrade-firmware-on-an-rv34x-series-router.html
 M.
Martin Aleksandrov
Hello, longbeard,
Yes, you can. With the RV series routers as marce1000 said there is no such a requirement so you can proceed with direct upgrade to the latest one.
Martin
