RV345 SSL VPN Setup Problem
aaronwan5611
RV345 SSL VPN enabled and configed all, but port:8443 no open ?
balaji.bandi
How is your connection to provider ?  you need to check with ISP any filters on their side, by default of this is configured the port open automatically for the connection.
Hope below guide can help you :
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5519-configure-secure-sockets-layer-virtual-private-network-ssl-v.html
BB
yes, I think so. I connected the router location . But, What I am puzzled is “tcping” tool detected the port 8443 no open.
