06-08-2021 06:46 PM
Is there a way to monitor the temperature of the Cisco RV345 router? I do have it in a climate controlled closet but I am still curious to see how hot it gets since it is fan-less. I did see an old thread about this being a feature request on the old RV320 series routers. But as of now, I don't see any such option, at least in the web console.
I was even thinking of mounting a 40mm usb exhaust fan on the side.
Solved! Go to Solution.
06-11-2021 02:19 AM
SNMP port 161 (162 is for trap) is the port, i do not where you mentioning this community here ?
i use other snmp test tool its free always handy
https://www.paessler.com/tools/snmptester
06-09-2021 02:33 AM
Not tested my self, Download the MIB as below Link and try snmpwalk see if you get any results :
https://software.cisco.com/download/home/286288298/type/282465797/release/1.0.1
06-09-2021 09:22 PM
Thanks I will try that out. Does it matter which SNMP version I use?
06-10-2021 12:13 AM
no the version not matter results will be the same v3 is more secured. but v2c still good.
06-10-2021 08:35 PM
Please forgive my ignorance, but I have never used SNMP before. I setup SNMPv3 and v2c on the router and set a name, contact, and location. Then set a trap IP and port then applied.
However, I don't know what to do next and I don't know what to do with that MIB download you linked to. I tried SNMPWalk from SolarWinds but I just get device not responding.
06-11-2021 02:19 AM
