Rv345 wan 2 issue
I just purchased a rv345. I have 2 static ips from my isp.  1 is working fine, I can't seem to get the static ip 2 to work. When I add ip 2 to wan 2  I can't click apply,  I get a red box saying The IP Address setting conflicts with an existing interface.
Static ip 1 is 66.x.x.152 static ip 2 is 66.x.x.205.  The xs are identical numbers only thing different between these 2 static ips are the last number.
If I can't add this 2nd static ip this way,  where do I add it, in routes? If so, how do I do so.
My 2 static ips are from the same isp and only 1 modem,  I do not have 2 seperate internet connections.   Please help and thank you, I'm not at all familiar with cisco products.
Peter vds
What is the subnet mask you use on WAN 1 and WAN 2?
Thank you for your help. Isp gave 255.25.255.0. I believe I may have just
accomplished what I needed by using static nating. I will find out later
today when company opens, tested ok from my home. Thanks again.
Hi! We have the same problem:
IP for WAN1 = 46.XX.YY.12
IP for WAN2 = 46.XX.YY.13
SUB: 255.255.255.240
We can't add the second IP on WAN2 (static IP) because we always get the error message: "The IP Address setting conflicts with an existing interface." How can we solve that major issue?
Using two IP addresses from the same network is not possible.  You need to get a separate Internet connection for WAN2.
