RV345 Web Filter License Renewal - Any Remaining Sources?
CapnSunshine
Hi, I am helping a non profit organization with their RV345. In the past we've purchased the web filter license from Provantage, apparently they no longer provide it. Have also checked with CDW and Google'd and we're not finding any resource.
Has anyone been able to renew their RV345 web filter license this year? If so, where did you purchase it from?
Or, Cisco, is it no longer available?
Thanks.
marce1000
  - Ref : https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/1332-how-to-purchase-and-setup-web-filter-licensing-on-the-rv340.html#purchase-a-security-license
   + As per instructions from the above contact your nearest Cisco partner and ask if it can still be done
       because of https://www.cisco.com/c/en/us/products/collateral/routers/small-business-rv-series-routers/small-business-rv340-rv345-series-eol.html
   M.
Thanks for the reply. Yes they were aware of the EOL dates. They are in the sticks and have no Cisco partner hence the ordering of the license online. SInce this appears to be the start of an ongoing hassle for them unless they want to change routers, they will likely just use an OpenDNS-ish solution for web filtering in the meantime and look for a new router solution from somewhere in the future. Thanks.  CS
