rv34x configure broadcast for printer from one VLAN to another
bigcat88
Router model RV345P with last firmware.
For example has 2 networks VLAN1 and VLAN2.
Printer lives in VLAN2 network.
It must be discoverable not only throw direct IP.
Is it possible?
P.S.: Inter-VLAN enabled, I can ping it, port on printer is reachable. But I don't know where to enable broadcast between VLANs(better to allow to broadcast only for printer)
Thanks.
balaji.bandi
ip direct-brodcast should be the command to pass over other VLAN, But Most of the RV has Limited command functionality.
broadcasts can be controlled using firewall ACL, but i have never done it. try that option.
BB
balaji.bandi
BB
