I am new here, so I ask for your grace in any "dumb" questions/assumptions I make below
I recently purchased a RVS4000 (firmware V2.0.0.3) and am having some issues creating a second (third...fourth?) IPSec VPN Tunnel.
The first one is up and running just fine. On the VPN Summary screen it says [1 Tunnels Used 4 Tunnels Available].
When I go to configure the second tunnel, I select --New-- from the "Select Tunnel Entry" dropdown and proceed to fill in all the connection information.
When I click Save, it seems to be processing and after a few seconds just returns me to the same screen, with none of the information I just input and no connection created. No errors given.
Any ideas on why this is happening? Any suggestions on things to try.
I have another RVS4000 to connect at a different location which will require a similar setup, but don't want to do anything with it unitl I have the one mentioned above working fully.
Thank you in advance for all your advice and suggestions in advance.
