09-20-2012 06:37 AM
I may have made a bad impulse buy. I purchased an RSV4000 for the sole reason that I was hoping I could simply set up a vpn user id and password and easily connect my android and iphone to my home network when I am away. Some of my apps are very dependent on my local ip scheme and dns. After an exhaustive night of reading I have come to learn that the VPN connection requires either a client or another router. If I am right, I need to buy another router to accomplish this. Which would be the easiest to set up. I don't want to rely on my windows or apple servers for the connection I want the router to handle it completely.
Any help or recommendations would be greatly appreciated.
John
Solved! Go to Solution.
09-20-2012 10:22 AM
Hi John, this probably is not the router for you. I'd recommend something like the RV042 for the PPTP function. This will make your life a bit better.
-Tom
Please rate helpful posts
09-20-2012 10:22 AM
-Tom
09-20-2012 12:15 PM
I would recommend RV042G, which is the gigabit version of RV042. They support 5 PPTP users.
