S2S VPN between an RV340 and an RV 130
Phönix-ETS
The following problem: S2S VPN between an RV340 and an RV 130. Address spaces 192.168.1.0 and 92.168.2.0. The access from the network of the RV 340 to the network of the RV130 works without problems, conversely, no data is transmitted. No address in the range 192.168.1.xxx can be called.
66 2018-10-01 09:33:10 debug ripd[10263]: multicast announce on lan side
67 2018-10-01 09:32:56 warning pluto[22112]: "AGS" #20: STATE_QUICK_R2: IPsec SA established tunnel mode {ESP=>0xca8051e6 <0x7b95a2a7 xfrm=3DES_0-HMAC_MD5 NATOA=none NATD=none DPD=enabled}
68 2018-10-01 09:32:56 warning pluto[22112]: "AGS" #20: transition from state STATE_QUICK_R1 to state STATE_QUICK_R2
69 2018-10-01 09:32:56 warning pluto[22112]: "AGS" #20: Dead Peer Detection (RFC 3706): enabled
70 2018-10-01 09:32:56 warning pluto[22112]: "AGS" #20: STATE_QUICK_R1: sent QR1, inbound IPsec SA installed, expecting QI2
71 2018-10-01 09:32:56 warning pluto[22112]: "AGS" #20: transition from state STATE_QUICK_R0 to state STATE_QUICK_R1
72 2018-10-01 09:32:56 warning pluto[22112]: "AGS" #20: keeping refhim=4294901761 during rekey
73 2018-10-01 09:32:56 warning pluto[22112]: "AGS" #20: them: XXX.XXX.15.222<XXX.XXX.15.222>[+S=C]===192.168.1.0/24
74 2018-10-01 09:32:56 warning pluto[22112]: "AGS" #20: us: 192.168.2.0/24===192.168.3.2<192.168.3.2>[+S=C]---192.168.3.1
75 2018-10-01 09:32:56 warning pluto[22112]: "AGS" #20: responding to Quick Mode proposal {msgid:ac73dcd5}
76 2018-10-01 09:32:56 warning pluto[22112]: "AGS" #13: the peer proposed: 192.168.2.0/24:0/0 -> 192.168.1.0/24:0/0
77 2018-10-01 09:32:39 debug ripd[10263]: multicast announce on wan side
pieterh
192.168.1.0 and 92.168.2.0 -> Typo? i assume 192.168.2.0
192.168.3.2 - 192.168.3.1 is the router interconnect network?
are you using static IP config or dhcp?
how is the client network configuration on the 192.168.2.0 side?
