Serveur PPTP RV320
LucLesourd10441
I cannot deactivate the PPTP server on a RV320 firmware 1.3.1.12 or change the address range displayed. If I install newer firmware, will this solve the problem? With old firmware it works.
Thank you for your help
marce1000
 - Check if hints provided in this thread can help you :
            https://community.cisco.com/t5/small-business-routers/rv325-firmware-v1-3-1-10-how-to-disable-the-pptp-server/td-p/2909397
 M.
