SIP ATA Behind RV220W
I am trying to configure a Cisco SPA8000 to function as a SIP ATA behind a RV220W router.   I cannot seem to get port forwarding working or otherwise allow the SIP traffic to the SPA8000.    When I replace the RV220W with another router / firewall everything works fine, but when I put in the RV220W I am not able to register etc.   I have been over and over the manual and "yes" I have the SIP ALG enabled.   Here is my setup:
Internet  =>  RV220W (public) => SPA8000 (private)
Can anyone suggest anything please?
Chris
P.S. on hold for nearly 3 hours waiting for Cisco support!!
CAT
7 Replies 7
Tom Watts
Hi Chris, using the 1.0.4.17 firmware, try to make the port forwarding under the access rules instead of using the port forwarding page.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom,
Thanks for the response.   I have done so.   I have created custom services for the UDP SIP and the UDP RTP ports and added them to the access rules without success.   I am in the process of downgrading to the 1.0.3.X firmware.
CAT
Chris,
have you managed to get it working?
i'm thinking about similar configuration RV220W and SPA8000.
Yes, I was able to get this working and it has been doing extremely well for about 4 months.   The key in my case was to make sure the SIP AGL was ENABLED.  The problem was that the service provider's SBC was seeing a non-routable IP address in the SIP header and was requiring a shorter registration interval than the endpoint.   The result was that the SBC would eventually deny the connection when the registrations got out of synch.
I can recommend this configuration now and for high SIP traffic (in excess of 12000 minutes per month on 5 channels).
Chris
P.S.  It was the service provider who insisted that the SIP AGL needed to be disabled in order for our configuration to work with their service!
Of course I mean "ALG" in both places above . . . . . sorry.
Thank you for responding!
i will keep that in mind. Hoping to get hardware in a few weeks.
