Site to Site VPN with RV180 to 5510 ASA
helpdesk-md
   Hello All, I am trying to establish a site to site VPN with a RV180 connecting back to a corporate Network using an ASA 5510.  I have the RV180 setup with the Remote IP setting and a FQDN all setup and  I am able to tracert back to the ASA but I wanted to know if I have to modify anything on the ASA side and how do I setup a pre-share key to establish the secure connection.  Any suggestions would greatly help.  Thanks
jonatrod
Level 7
Level 7
Good morning
Hi Jeff, thanks for using our forum, my name is Johnnatan and I am part of the Small business Support community. I ´ve seen your post and I found some information related to your RV180
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2863
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2284
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2265
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2264
Also if you want to configure the preshared key in your ASA5510 you can setting up with this commands:
crypto isakmp enable
authentication pre-share
crypto isakmp key address/ hostname
If you need more help you can post your question in  Security > VPN so you can have more feedback on your case, more users will see it there. I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
