srp521w vpn help
rockylee1966
need help with cisco srp521w router vpn configuration.
company has wan static ip to router
enable vpn cisco server in router. connected with cisco vpn client.  route failed in log.
need to access a pc on the company site with address 192.168.15.105
router with gateway 192.168.15.1
how do i configure ip pool ? different ip address? if i connect how do i access pc 192,168.15,105 ?
remote pc with 192.168.1.100
i am a newbie..need help in setup of vpn.
Andrew Hickman
Hi Cory,
Can you provide a little more detail of your configuration please?  Perhaps post a screenshot of the VPN configuration page.
It should be possible to use any IP address range for the pool - provided that it doesn't overlap with any of your VLAN IP subnets...can you check that?
From your comment, can I assume that the remote PC is assigned 192.168.1.100 from the pool you configured?  Or is this the locally assigned address from the router it is connected to?
Andy
the company is shutdown for the holiday of july 4. i can not provide screenshot yet.
i think i found the solution.
the remote pc(my house) is on 192.168.1.100 and company is using srp521w with 192.168.15.1 gateway, 192.168.15.100 to 150 ip range in dhcp
i guess i assign unused portion starting with 192.168.15.120 for the ip pool in the srp521w router. so when i connect with cisco vpn client it will grap 192.168.15.120  i will check my route table log in the client.
thank you for the hint
