SRP527W with Split Tunnel
Bryce Ryan
Hi Guys,
I've just deployed a SRP527W that I've had lying around for a while.
Everything on the unit runs as well as can be expected, however I have a requirement to run split tunneling for VPN users.
Currently the only route that the VPN client receives is a default route. I noticed that on site to site VPN's and GRE tunnels you can specify secured routes, however I can't find anything that relates to the VPN remote users. This can be done on IOS without a problem but would be nice for the SRP.
I'm running the latest firmware 1.01.26, so if I haven't overlooked something would this be likely for a future release?
Cheers.
Bryce
Andrew Hickman
Hi Bryce,
Nothing overlooked, it is not possible to configure split tunnelling for the SRP VPN server.
Andy
Andrew Hickman
Hi Bryce,
Andy
Hi Andy,
No problems, thanks for your answer.
Hopefully this will pushed as feature to newer firmware.
Cheers.
Bryce
