SRP547W - where is ADSL uptime
mhornsby3941
The status page doesn''t display the ADSL connect time, is there a simple way of seeing how log the ADSL has been connected ??
Tom Watts
Hello Michael, under the Status -> Interface it does not display here? If you are familiar with SNMP that may be an option for you.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom
Thanks for your reply. The interface status just gives me packets transferred on each port.
The ADSL status is where I would have expected to find it but it just gives my sync speeds and various other things
Any chance CISCO might consider adding ADSL up ttime of this page
Gary Schlender
Try Adminsitration Menu > Remote Support option item > click on Collect Device Status Information.
You should get an automatic download of a log folder containing various compressed log files.
Look in the dump_dslmodem_cmd.txt file.  The info you are looking for is there...I agree, not easy to find.
Thanks Gary
Thanks - thats what I thought. There is also a hidden disganostics page I read somewhere on this forum which would give me simlar info . But you have confirmed what I thought its not on a Status page .
Michael
