two RV042 [Authorize Fail] no connection has been authorized with policy=PSK+AGGRESSIVE
ARGJ
hi, guys thanks for time and help i need a guide for configure this crap of routers
SITE A Static WAN IP X.X.X.X to 10.0.0.7 ipsec/vpn ports
SITE B Dinamyc IP Address DynDNS
1 - First the Remote branch office RV042 when i enable the DynDNS services is updating the host whit the internal ip of the router
example 10.0.0.13
2 - Second the vpn only work when is set the ip addres of the remote office in the main office and not whit the domain name i get this error:
Aggressive mode Enable:
Aggressive mode Disable:
Jan 1 05:41:41 2010VPN Log(g2gips0)[4] 186.6.29.68:2231: [Tunnel Disconnected] instance with peer 186.6.29.68 {isakmp=#0/ipsec=#0}
Jan 1 05:41:41 2010VPN Logpacket from 186.6.29.68:2231: [Tunnel Authorize Fail] 'g2gips0' forbids connection, cause: Aggressive Mode
Configuration both sites
SITE A:
WAN1
Local Group Setup:
IP ONLY
IP ADDRESS: 10.0.0.7(NAT)
Subnet
192.168.0.0
255.255.255.0
Remote Group Setup:
DYNAMIC IP + DOMAIN NAME FDQN AUTH
mysite.dyndns.org
Subnet
192.168.1.0
255.255.255.0
Aggressive Mode (Checked, unable to  disable or enable)
Keep-Alive Enable
Netbios Broadcast Enable
NAT-Traversal Enable
Deep Inspection Enable
SITE B:
WAN1
Local Group Setup:
IP ONLY
IP ADDRESS: 10.0.0.13(NAT)
Subnet
192.168.1.0
255.255.255.0
Remote Group Setup:
IP: 196.3.81.44
mysite.dyndns.org
Subnet
192.168.0.0
255.255.255.0
Aggressive Mode (i can enable or disable)
Keep-Alive Enable
Netbio Broadcast Enable
ARGJ
it seems that in this place the staff respond when he feels like if a person enters a community and posts a question is because you need assistance
where is the staff or technical support?
buy 15 of these routers to 15 remote offices to vpn but I see that it is very difficult with these teams had I dreamed that these routers are so bad and with so little information and support have bought juniper
Hi Arnaldo,
For immediate help, please contact the Cisco Small Business Support Center.  The contact information is located here: https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cindy
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
Thanks Cindy for your time and help!!!!
to late in the weekend i change all RV042 for Juniper al vpn are up and working!
thanks take care!
