Unable to upgrade firmware on RVS4000
Dean Wilson
Currently on V1.3.0.5. Looking to upgrade to latest version, however the upgrade firmware page is greyed out. Same under Firefox 9 or IE 8. I have already rebooted router, with no change in behavior.
DominikAu
are you trying to start the upgrade via a vpn or via the wan remote management port?
i think it's just enabled if you are in the "LAN" section of the router.
regards
Dominik
jasbryan
Level 6
Level 6
Dean,
If you're via remote management @ RVS4000 , and under firewall tab make sure you are allowed remote upgrades. now be very careful as this could possible brick the RVS4000 if you upgrade over vpn,remotely and wirelessly. You want to verify hardware version and upgrade in increments.
Jasbryan
