VPN Gateway-to-gateway connection between 2 RV042 succesfull, but no ping
frank0009
Beginner
Beginner
Hi all,
I'm getting a little crazy here, I've installed 2 identical RV042 routers on 2 locations. I installed a Gateway-to-gateway VPN connection, the routers connect with eachother... But I can't ping from one network to another.
I've disabled the firewal entirely (just for testing purposes), and tried pinging with the "diagostic tool" (via System Management) to exclude any problems with my computer. What the heck am I missing here?
MY CONFIG
ROUTER 1
Local Group Setup
IP Only
Group Type: Subnet
IP: 192.168.1.0
Subnet: 255.255.255.0
Remote Group Setup
IP Only
Group Type: Subnet
IP: 172.16.0.0
subet: 255.255.0.0
Enabled NAT Transfer, etc...
ROUTER 2
Local Group Setup
IP Only
Group Type: Subnet
IP: 172.16.0.0
subet: 255.255.0.0
Remote Group Setup
Group Type: Subnet
IP: 192.168.1.0
Same options enabled.
I played around with the IP / Subnet group types. to no avail.. I'm really at a loss here... why doesn't it just work. When I tried the exact same setup last year at the same location it worked perfectly.
7 Replies 7
Samir Darji
Contributor
Contributor
It seems like everything should work fine, especially since you got them to work before.
But I've been where you are, and it's something small that you've missed that makes the configuration between the two different.  Check the logs for clues and just go over both configurations with a fine-tooth comb.  Good luck.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
Chris Tremayne
Beginner
Beginner
I just posted a very similar problem.  I did find that when I pinged from office 2 to office 1, it did not work, but when I pinged from office 1 to office 2, it did and then would ping both ways.  My problem is that it stops working after a while.
Do you have keep alive and dead peer detection enabled?  What do you do to get it working again?
Yes, I had keep alive and dpd enabled.  I haven't found a solution yet.
Try disabling dpd.  I noticed that I only have keep alive enabled on my rv016 and remember that when I had both enabled, the tunnel would drop.
Yea.  I read that in a different post.  Didn't seem to make a difference either.
Strange.  So let's try this just to test if it's the router or something else.  Run a constant ping from office 1 to 2 using a workstation at office 1.  See if the tunnel drops then.  If it does, then it's actually something up with one of the routers.
Recognize Your Peers
