09-02-2025 07:45 PM
Hi I have a RV325 machine with firmware revision v1.5.1.13 which seems very old.
Does anyone know where to download the latest firmware for this EOL machine ?
Thanks !
Solved! Go to Solution.
09-03-2025 01:08 AM
Hello @roylulala,
as you know these routers have reached EOL several years ago already.
If I remember correctly that firmware you mentioned was the last and final release for the RV325.
So you are already running the lastest firmware for this router.
HTH!
09-03-2025 01:36 AM
If the cisco removed due to EOL you wont be able to download any more, you need to reach SMB support.
09-03-2025 01:08 AM
Hello @roylulala,
HTH!
09-03-2025 01:36 AM
