02-24-2012 07:46 AM
Hi there,
I have a DSL line at work that we use to test external services provided to external users on our primary Internet circuit (Citrix, web applications, etc). Because this DSL line is for testing only, we want to lock it down so the only destinations allowed through the firewall are our own IP spaces.
I purchased a WRVS4400N for this purpose, thinking I could use the IP based ACL list to create these restrictions. However, every time I try to create an ACL, the internet slows to a crawl, and many sites don't come up at all. This occurs even if the ACL rule I add is a simple "allow any any" rule similar to the default rules.
Is this a known issue, or am I configuring something incorrectly? Here's an example of a rule I'm using (IP not real):
Action Service Source Interface Source Destination Time Day
Allow All Protocol LAN ANY 1.2.3.0/255.255.255.240* Any Time Every Day
I also get the problem with a simple allow from a single IP (mine) to any destination, without any other rules enabled.
Any ideas on what I'm doing wrong, or is there something wrong with the implementation of the ACL ruleset on these routers?
Thanks in advance,
John
02-24-2012 08:26 AM
John,
WRVS4400N only allows for WAN to LAN or LAN to WAN ACL's- IP ACL's doesn't allow for LAN to LAN restrictions so that being said you are specifying to allow all protocols from sourceLAN(any lan source) outbound to 1.2.3.0/255.255.255.240 any time every day. By default all outbound traffic is allowed so unless you have a denied statement you don't need this rule. Also make sure you running latest firmware for this unit.
What is the local address of the WRVS4400N?
What are you trying to deny or restrict?
Jasbryan
02-24-2012 10:48 AM
Hi Jasbryan,
Thanks for the reply. I apologize for the lack of clarity in my explanation - I was trying to be brief.
I'm trying to restrict clients on the LAN interface from accessing any IPs on the WAN interface except for the IP ranges we own, which are in a different location on different ISPs. There is a DENY ALL ALL statement at the end of the ACL list. The ACL I listed in my original post was a single example of several ACL entries for the various IP ranges we own that we want to test from. So, it ends up looking something like this:
Allow All Protocol LAN ANY 4.5.6.0/255.255.255.240* Any Time Every Day
Allow All Protocol LAN ANY 7.8.9.0/255.255.255.240* Any Time Every Day
Allow All Protocol LAN ANY 11.12.13.0/255.255.255.240* Any Time Every Day
Deny All Protocol ANY ANY ANY Any Time Every Day
Again, the IPs are made up, and are just for illustration.
The problem occurs in that whenever there are *any* created ACL rules in place and enabled, the connection slows so much as to be unusable to most sites. This even occurs if I were to disable the above and only enable a *single* rule, something like this:
Allow All Protocol LAN 192.168.200.100 ANY Any Time Every Day
This single rule should allow my PC (which has been statically assigned the 192.168.200.100 address) full access to the Internet, however I see extreme slowdowns which makes the system unusable. I realize the rule is redundant when none of the other rules are in place, but I'm using it to illustrate my point that the enabling the ACL filtering seems to cause a significant slowdown on the system.
I am running the latest version of firmware available on Cisco's website, 2.0.2.1.
When you say "local address of the WRVS4400N", are you referring to the LAN interface address, or the WAN interface address? The local LAN address is 192.168.200.1.
Hope that provides a more thourough explanation. Thanks for the help!
John
02-28-2012 07:00 AM
Bumping the thread to see if anyone has any additonal feedback, as I'm still having the issue. Thanks!
02-28-2012 07:25 AM
John,
I would get more specific on my rules and not using ANY beside on your Destination. Other than that you'll need to call into the support center so we can take a look at your setup and start trouble shooting. We'll probably have to lab up your configuration and find out possible cause of your problem.
Jasbryan
02-28-2012 07:27 AM
Thanks, Jasbryan. I'll contact the support center.
John
