877 router reset itself, no ADSL connection after restoring config
Zenith888
Level 3
Level 3
There was no Internet connection this morning and I looked at the router - the CD light was blinking fast.
Router did not respond to SSH connection and I plugged in the console cable.
sh run had factory default configuration. So I've restored the last running config, but still would not have Internet.
CD light continues to flash frequently and this is what router reports:
#sh dsl int atm0
ATM0
Alcatel 20190 chipset information
Line has not yet been activated.
Modem Status:    Down (DMTDSL_DO_OPEN)
DSL Mode:        Unknown
Interrupts:      8238 (0 spurious)
PHY Access Err:  0
Activations:     0
LED Status:      OFF
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR-4.0.015.bin
Operation FW:    AMR-4.0.015.bin
FW Source:       external
DSL: Training log buffer capability is not enabled
As of now I am connected thru a combination of SpeedTouch modem and DLink router as a backup.
Is there any way to diagnose what is missing for the DSL connection to be established by 877?
35 Replies 35
Can you point out the mistakes?
That config did not produce PPPoE connection on either line no matter how long I waited.
How can I diagnose dialers when using Eth ports for PPPoE?
You need pppoe command on vlan interface, not indivividual ones.
You need to create and asociate new vlan interfaces.
How? I thought that by now it should have been clear that I don't know how to achieve that. And that's why I came to this forum.
Is this a correct config? Please help!
interface ATM0
no ip address
shutdown
interface FastEthernet0
switchport access vlan 2
pppoe enable group global
no cdp enable
interface FastEthernet1
no cdp enable
interface Vlan2
description WAN Vlan
no ip address
ip tcp adjust-mss 1452
pppoe-client dial-pool-number 1
interface Dialer0
description PPPoE dialer for ISPline0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1464
ip nat outside
ip virtual-reassembly
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp pap sent-username user1 password 0 pass1
ppp ipcp route default
ppp multilink
interface Dialer1
description PPPoE dialer for ISPline1
no ip redirects
no ip proxy-arp
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username user2 password 0 pass2
ppp multilink
Zenith888
Level 3
Level 3
How to configure load balancing for 2x DSL lines using the ethernet ports on 877.Please help!
