Add vBond to vMange
Juraj Papic
Level 5
Level 5
Hi all
Im working with viptela version 18.4.1 every time I try to add the vBbond to the vMange I get this error
java.net.SocketTimeoutException: connect timed out
Thanks.
29 Replies 29
Yes, it is working now.
Jason Xie
Frequent Visitor
Frequent Visitor
I have the same issue too when adding the vBond to the vManager. Have this issue been resolved?  I have tried the solutions proposed but still not good.
Jason
The issue has been resolved by installing the correct version of the vBond.
Thanks all for your help!
Jason
Mahmoud Elsoury
Frequent Visitor
Frequent Visitor
I know this is an old topic, but I just wanted to share how I solved mine.
I'm running version 20.6.3 and had the same error.
Problem solved after adding the "local" keyword to the vbond command on vbond itself.
i.e. when I had the problem I had:
vbond 10.10.1.106
the correct one which solved the problem:
vbond 10.10.1.106 local
I hope that helps anyone.
Thanks for this! I was setting up a lab in CML and this was exactly my issue adding the vbond in vManage.
Previous troubleshooting I also enabled sshd and netconf on the tunnel-interface under my main interface.
ibnoesany28
Frequent Visitor
Frequent Visitor
Hii,
reconfigure vbond vpn 0 and set "no tunnel-interface"
ex:
vpn 0
interface ge0/0
ip address x.x.x.x/x
no tunnel-interface
no shutdown
This worked for me too, quiet helpful.
It worked for me 👍
rward2801
Does not work for me
Cisco vBond error Failed to add device java.io.IOException: Unable to connect to admin@1.1.1.3:830
vManage
vpn 0
dns 8.8.8.8 primary
interface eth1
ip address 1.1.1.1/24
no shutdown
vBond
vpn 0
interface ge0/0
ip address 1.1.1.3/24
ipv6 dhcp-client
no shutdown
I had the same issue and my solution was to enable the tunnel interface on the vbond and allow all services:
config
vpn 0
interface ge0/0
tunnel-interface
encapsulation ipsec
allow-service all
commit and-quit
This also helped for my deployment.
vBond# show version
20.9.4
conf t
 vpn 0
  interface ge0/0
    tunnel-interface
      encapsulation ipsec
      allow-service all
      commit and-quit
edit: I don't think you actually need to specify the "allow-service all". Just adding "tunnel-interface" and "encapsulation ipsec" should do the trick.
Thank you, this was absolutely my issue. I didn't have to add the tunnel interface on VPN 0 for vSmart, but had to absolutely do it for vBond. After hours of troubleshooting.
vpn 0
interface ge0/0
ip address 10.1.1.2/24
tunnel-interface
encapsulation ipsec
allow-service all
no allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
no allow-service sshd
no allow-service netconf
no allow-service ntp
no allow-service ospf
no allow-service stun
allow-service https
dawodi55
Visitor
I had the same issue and my solution was to disable the tunnel interface on the vbond.
version 19.2.31.
pgasparovic
Level 4
Level 4
Hello, same here with sample 20.9.3 code, only tunnel-interface on vBond helped me to refresh my lab after long time of having EMS certificates expired.. This is kinda grey zone of technology, greatly undocumented. Question if vManaged alive device would comply, avoiding this helper..
