Alarms on WIC cards- and they are not in show hardware either.
Steve Waechter
Community Member
I have several 2811s before me.
They each have VPN module,
VWIC-1MFT-T1 channelized T1 and WIC-1DSU-T1-V2 WICs.
I booted one and the WIC-1DSU-T1 does not appear at bootup time in console output.
The VWIC does appear, as you can see below.
I thought, that's odd, so in looking at the WICs they have yellow alarms on them. AIM0 on the chasis is also illuminated yellow.
I did a write erase, that didn't change anything.
Here's the show hardware:
Router>ena
Router#sho hard
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(3d), R
ELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 19-Apr-06 09:18 by alnguyen
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
Router uptime is 47 minutes
System returned to ROM by reload at 21:47:14 UTC Fri Feb 21 2014
System image file is "flash:c2800nm-advsecurityk9-mz.124-3d.bin"
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FTX1023A3DD
2 FastEthernet interfaces
1 Serial interface
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
I looked at several more units and they all have similar symptoms.
Alarms, WICs not in the console. It's not normal to have so many failures.
These were taken out of a moved data center.
I haven't had much experience with bad WICs.
Could these all be actually bad?  Or is there something I am missing?
I have nothing plugged into the unit except power and my console cable. I first thought the alarms might be a setting because of loss of carrier, or connection, something.  Which is why I did the write erase.
Leo Laohoo
WIC-1DSU-T1
I don't think this is supported on the 2800.
For 2800 you need the HWIC-1DSU-T1.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-speed-wan-interface-cards/datasheet_c78-491363.html
Well, this is hard to understand.  As Leo says the HWIC is supported.  But here it seems to say those same slots support WICs:
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/prod_qas0900aecd80169bd6.html
Interface card slots: Each version can accommodate HWICs. These HWIC slots also support VICs, VWICs, and WICs. Alternatively, two side-by-side HWIC slots can be substituted to seat one double-wide HWIC (HWIC-D).
4 slots total: 2 slots support HWIC, WIC, VIC, or VWIC type modules, where 1 of the 2 slots supports WIC, VIC, or VWIC type modules and the other slot (2 of 2) supports VIC or VWIC type modules
johnlloyd_13
Level 11
Level 11
Hi Steve,
I believe it's supported.
Could you post 'show diag'?
