Routing and SD-WAN
Labels
Good day,on core switch 3850working config:ip access-list standard VLAN7_WIFI10 permit 10.1.7.0 0.0.0.255!route-map PBR permit 10match ip address VLAN7_WIFIset ip next-hop 10.1.98.74 ----(ASA-2)!interface Vlan3description to-default-gwip address 10.1...
s_SiD_s by Level 3
  • 570 Views
  • 11 replies
as we know, router ID is not needed in ISIS and usually not configurable, however in IOS XR you may configure router ID in the ISIS instance. what is the purpose of this configuration?
daniel ng by Spotlight
  • 320 Views
  • 7 replies
Hello!  I have a home lab, and I can ping the internal interface on a small router, but I cannot reach the internal port, thus no traffic is passing through to the firewall.  I have the correct routes, and I am debugging ping, and I see no messages. ...
Grant73 by Visitor
  • 329 Views
  • 4 replies
Hello A few days ago I wanted to install a cisco ASR920 DC.Configured in advance I thought everything should go smoothly, but this wasn't the case.The cisco ASR920 keeps rebooting, telling me it does not find any bootflash:/ With other types of cisco...
Bekers by Community Member
  • 19203 Views
  • 17 replies
Having an issue where wifi calling is not working. There is an inbound ACL on the router, and we have narrowed troubleshooting down to it being the issue. If we add permit ip any host "external_IP" log at the end, the calling works. As soon as its re...
Hello, all and @Royalty  We currently have two Data Centers. Each data center has a 100Gbps Internet connection. We have a Cisco ASR1001 edge router which connects to a core switch on the LAN side.    I am considering two SD-WAN design options for th...
ZK916 by Level 3
  • 231 Views
  • 5 replies
Hi GuysI am investigating a BFD issue that is causing a OSPF flapping when the link is oversubscription. The OSPF and BFD is running in the ASR903 and the OSPF adjacencies is going down many times. In the log of both routers I am able to see this err...
maverick0 by Level 2
  • 6190 Views
  • 2 replies
  • 6 Helpful votes
