Cisco ASA 5505 VPN trouble
Kabashik
Community Member
Hi everyone! Unknown error while configuring ASA's VPN. All commands are clear and 100% right, but when we start to test how it works we have error " The interesting traffic can not be encrypted, IKE (ISAKMP) needs to negotatiate IPSec SAs." A lot of different sources red, but don't know what to do with this. Screens and configs are below. Thanks!
Georg Pauwen
if this is a Packet Tracer project, post your zipped project (.pkt) file.
6 Replies 6
Georg Pauwen
Georg Pauwen
Looking at the router configuration, there is no routing at all. Are you sure you sent the configuration of the correct router (the ISP router in your drawing) ?
Already downloaded .pkt, you can watch and write me
Kabashik
Community Member
Already fixed, thanks everyone!
it seems to work just fine. The routing on the ISP router has been added, I can ping and get a valid SA:
Crypto map tag: TESTMAP, seq num: 10, local addr 192.168.1.2
permit icmp 192.168.3.0 255.255.255.0 192.168.4.0 255.255.255.0
local ident (addr/mask/prot/port): (192.168.3.0/255.255.255.0/1/0)
remote ident (addr/mask/prot/port): (192.168.4.0/255.255.255.0/1/0)
current_peer 192.168.2.2
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
#pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
#PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
#send errors 1, #recv errors 0
local crypto endpt.: 192.168.1.2/0, remote crypto endpt.:192.168.2.2/0
path mtu 1500, ip mtu, ipsec overhead 78, media mtu 1500
current outbound spi: 0x26E65432(652629042)
current inbound spi: 0x378A033A(652629042)
inbound esp sas:
spi: 0x378A033A(931791674)
transform: esp-aes esp-sha-hmac no compression
in use settings ={L2L, Tunnel, }
slot: 0, conn id: 2002, crypto map: TESTMAP
sa timing: remaining key lifetime (k/sec): (4525504/86396)
IV size: 16 bytes
replay detection support: N
Anti replay bitmap:
0x00000000 0x0000001F
outbound esp sas:
slot: 0, conn id: 2003, crypto map: TESTMAP
IV size: 16 bytes
Anti replay bitmap:
0x00000000 0x00000001
