Cisco C4507R High CPU Utilization
Ibrahim Alsharif
Community Member
Hello Dears,
we have 2 Cisco C4507 Switches working As Core Layer, but the CPU Utilization is about 54% most of the time and sometimes it goes up to 70% or 80% also.
could you please help me to sort out what is the problem and which services are causing this utilization.
attached are the following commands:
show proc cpu sort
show proc cpu history
show platform health
show platform cpu packet statistics
show version
Thanks in Advance.
Ibrahim
InayathUlla Sharieff
ASAK Ibrahim,
Nice way to start troubleshooting high cpu on 4500:
http://www.cisco.com/en/US/customer/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
I will go through your data in free time and get back to you.
Inayath
Thanks for your help Inayath,
I'm working on the document that you sent but need some help to figure out the issue.
Ibrahim
Ibrahim,
Quick check been done:
HQ-Core-SW1#show proc cpu sort
CPU utilization for five seconds: 47%/2%; one minute: 52%; five minutes: 53%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  58   143527896 223239200        642 22.31% 23.24% 23.45%   0 Cat4k Mgmt HiPri
  59   107245868  32667072       3282 13.11% 15.79% 16.84%   0 Cat4k Mgmt LoPri
HQ-Core-SW1#show platform health
K2FibAdjMan Host Mov   2.00  10.55     10      7  100  500    7   1    0  50:34
Packets Dropped In Processing by CPU event
Event             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Input Acl                           94         0         0         0          0
SA Miss                            423         0         0         0          0
Packets Received by Packet Queue
Queue                  Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Esmp                          75227557       151       135        99         88
L2/L3Control                  30124260        62        49        39         37
Host Learning                   570567        12         1         0          0
L3 Fwd High                          3         0         0         0          0
L3 Fwd Medium                      711         0         0         0          0
L3 Fwd Low                   113038876         7         3         4          9
L2 Fwd High                         27         0         0         0          0
L2 Fwd Medium                      337         0         0         0          0
L2 Fwd Low                    30481636       106        83        64         62
L3 Rx High                      191124         0         0         0          0
L3 Rx Low                     13281002        24        16        15         12
ACL log, unreach                209896         0         0         0          0
Not quite sure which Q is hitting more as we need to run this command couple of time.
Action plan:
-> Kindly check if there are any host flapping occuring in the logs.
-> Configure Mac Move notification and you would see the flaps in the logs.
Inayath
Hi Inyath,
see below logs, there are mac move notifications always.
the 2 mentioned VLANs 80 & 90 are Wireless VLANs, so I guess the movement is normal for those 2 VLANs.
*Jun 12 07:02:55: %SYS-5-CONFIG_I: Configured from console by bunnak.so on vty0 (10.13.2.97)
*Jun 12 07:07:09: %C4K_EBM-4-HOSTFLAPPING: Host 08:3E:8E:70:4A:7F in vlan 90 is moving from port Po10 to port Gi5/4
*Jun 12 07:07:21: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:82:3B:03:F6 in vlan 80 is moving from port Po10 to port Gi5/4
*Jun 12 07:07:38: %C4K_EBM-4-HOSTFLAPPING: Host 08:3E:8E:70:5D:2B in vlan 80 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:07:43: %C4K_EBM-4-HOSTFLAPPING: Host 60:67:20:7D:C2:08 in vlan 80 is moving from port Po10 to port Gi5/4
*Jun 12 07:07:55: %C4K_EBM-4-HOSTFLAPPING: Host 00:21:6B:9E:4E:94 in vlan 80 is moving from port Po10 to port Gi5/4
*Jun 12 07:08:06: %C4K_EBM-4-HOSTFLAPPING: Host 8C:A9:82:70:EF:A2 in vlan 90 is moving from port Gi5/2 to port Gi5/1
*Jun 12 07:08:13: %C4K_EBM-4-HOSTFLAPPING: Host A0:88:B4:C4:89:44 in vlan 80 is moving from port Gi5/2 to port Po10
*Jun 12 07:08:26: %C4K_EBM-4-HOSTFLAPPING: Host 08:3E:8E:70:48:3A in vlan 80 is moving from port Gi5/2 to port Gi5/3
*Jun 12 07:08:45: %C4K_EBM-4-HOSTFLAPPING: Host 08:3E:8E:70:5D:2B in vlan 80 is moving from port Gi5/4 to port Gi5/3
*Jun 12 07:08:47: %C4K_EBM-4-HOSTFLAPPING: Host 00:1F:3C:0C:29:4B in vlan 80 is moving from port Gi5/4 to port Gi5/3
*Jun 12 07:08:50: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:82:3B:02:E5 in vlan 90 is moving from port Gi5/2 to port Gi5/3
*Jun 12 07:08:54: %C4K_EBM-4-HOSTFLAPPING: Host 10:0B:A9:75:11:74 in vlan 80 is moving from port Gi5/4 to port Gi5/3
*Jun 12 07:08:55: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:82:D2:64:39 in vlan 80 is moving from port Gi5/2 to port Gi5/3
*Jun 12 07:08:56: %C4K_EBM-4-HOSTFLAPPING: Host 00:21:6B:9F:94:32 in vlan 80 is moving from port Gi5/2 to port Gi5/3
*Jun 12 07:08:56: %C4K_EBM-4-HOSTFLAPPING: Host 10:0B:A9:07:AD:6C in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:08:57: %C4K_EBM-4-HOSTFLAPPING: Host 58:94:6B:06:8D:14 in vlan 90 is moving from port Gi5/2 to port Gi5/3
*Jun 12 07:09:01: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:09:03: %C4K_EBM-4-HOSTFLAPPING: Host CC:08:E0:EA:8F:50 in vlan 90 is moving from port Po10 to port Gi5/2
*Jun 12 07:09:08: %C4K_EBM-4-HOSTFLAPPING: Host CC:08:E0:EA:8F:50 in vlan 90 is moving from port Gi5/2 to port Gi6/1
*Jun 12 07:09:11: %C4K_EBM-4-HOSTFLAPPING: Host 10:0B:A9:07:AD:6C in vlan 90 is moving from port Gi5/4 to port Gi5/3
*Jun 12 07:09:12: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:C7:28:84:6A in vlan 80 is moving from port Gi5/2 to port Po10
*Jun 12 07:09:23: %C4K_EBM-4-HOSTFLAPPING: Host 00:21:27:B9:69:3D in vlan 90 is moving from port Gi5/4 to port Gi5/3
*Jun 12 07:09:39: %C4K_EBM-4-HOSTFLAPPING: Host 08:11:96:DA:E4:08 in vlan 80 is moving from port Gi5/4 to port Gi5/3
*Jun 12 07:10:08: %C4K_EBM-4-HOSTFLAPPING: Host A0:88:B4:28:0D:0C in vlan 80 is moving from port Gi5/4 to port Gi5/3
*Jun 12 07:10:57: %C4K_EBM-4-HOSTFLAPPING: Host 00:21:6B:9F:71:5A in vlan 80 is moving from port Gi5/4 to port Gi5/3
*Jun 12 07:11:14: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:11:25: %C4K_EBM-4-HOSTFLAPPING: Host 00:21:6B:85:53:BC in vlan 80 is moving from port Po10 to port Gi5/4
*Jun 12 07:11:27: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:82:3B:04:2C in vlan 80 is moving from port Po10 to port Gi5/4
*Jun 12 07:11:41: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:82:D4:30:A6 in vlan 80 is moving from port Gi5/2 to port Gi5/3
*Jun 12 07:11:54: %C4K_EBM-4-HOSTFLAPPING: Host CC:08:E0:8B:3D:0A in vlan 90 is moving from port Po10 to port Gi5/4
*Jun 12 07:12:21: %C4K_EBM-4-HOSTFLAPPING: Host C8:6F:1D:29:6C:F3 in vlan 90 is moving from port Gi5/2 to port Po10
*Jun 12 07:12:35: %C4K_EBM-4-HOSTFLAPPING: Host C8:6F:1D:29:6C:F3 in vlan 90 is moving from port Po10 to port Gi5/4
*Jun 12 07:13:03: %C4K_EBM-4-HOSTFLAPPING: Host CC:08:E0:8B:3D:0A in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:13:23: %C4K_EBM-4-HOSTFLAPPING: Host CC:08:E0:8B:3D:0A in vlan 90 is moving from port Gi5/2 to port Gi5/1
*Jun 12 07:14:02: %C4K_EBM-4-HOSTFLAPPING: Host CC:08:E0:8B:3D:0A in vlan 90 is moving from port Gi5/1 to port Gi6/1
*Jun 12 07:16:51: %C4K_EBM-4-HOSTFLAPPING: Host 3C:D0:F8:AE:06:47 in vlan 90 is moving from port Po10 to port Gi5/4
*Jun 12 07:16:55: %C4K_EBM-4-HOSTFLAPPING: Host 3C:D0:F8:AE:06:47 in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:17:09: %C4K_EBM-4-HOSTFLAPPING: Host 4C:8D:79:D4:81:48 in vlan 90 is moving from port Gi5/1 to port Gi5/2
*Jun 12 07:18:43: %C4K_EBM-4-HOSTFLAPPING: Host 58:94:6B:75:FA:F0 in vlan 90 is moving from port Gi5/4 to port Gi5/3
--More--                           *Jun 12 07:19:00: %C4K_EBM-4-HOSTFLAPPING: Host 20:68:9D:D9:B2:48 in vlan 90 is moving from port Gi5/2 to port Gi6/1
*Jun 12 07:19:03: %C4K_EBM-4-HOSTFLAPPING: Host 20:68:9D:D9:B2:48 in vlan 90 is moving from port Gi6/1 to port Gi5/2
*Jun 12 07:19:41: %C4K_EBM-4-HOSTFLAPPING: Host 20:68:9D:D9:B2:48 in vlan 90 is moving from port Gi5/2 to port Gi6/1
*Jun 12 07:21:07: %C4K_EBM-4-HOSTFLAPPING: Host 7C:FA:DF:96:1D:A2 in vlan 90 is moving from port Po10 to port Gi5/4
*Jun 12 07:21:19: %C4K_EBM-4-HOSTFLAPPING: Host A0:88:B4:CE:A8:50 in vlan 80 is moving from port Gi5/3 to port Po10
*Jun 12 07:22:16: %C4K_EBM-4-HOSTFLAPPING: Host 7C:FA:DF:96:1D:A2 in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:22:22: %C4K_EBM-4-HOSTFLAPPING: Host 90:18:7C:66:0A:8D in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:23:25: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:24:21: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:24:39: %C4K_EBM-4-HOSTFLAPPING: Host 54:26:96:0E:F4:10 in vlan 90 is moving from port Gi6/1 to port Po10
*Jun 12 07:25:13: %C4K_EBM-4-HOSTFLAPPING: Host 00:21:6B:73:C4:2E in vlan 80 is moving from port Po10 to port Gi5/2
*Jun 12 07:25:28: %C4K_EBM-4-HOSTFLAPPING: Host 00:21:6B:73:C4:2E in vlan 80 is moving from port Gi5/2 to port Gi5/3
*Jun 12 07:25:40: %C4K_EBM-4-HOSTFLAPPING: Host 3C:D0:F8:AE:06:47 in vlan 90 is moving from port Gi5/2 to port Po10
*Jun 12 07:25:57: %C4K_EBM-4-HOSTFLAPPING: Host CC:08:E0:8B:3D:0A in vlan 90 is moving from port Gi6/1 to port Gi5/1
*Jun 12 07:26:46: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:26:50: %C4K_EBM-4-HOSTFLAPPING: Host CC:08:E0:8B:3D:0A in vlan 90 is moving from port Gi5/1 to port Gi5/4
*Jun 12 07:26:57: %C4K_EBM-4-HOSTFLAPPING: Host CC:08:E0:8B:3D:0A in vlan 90 is moving from port Gi5/4 to port Po10
*Jun 12 07:27:29: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:33:25: %C4K_EBM-4-HOSTFLAPPING: Host 98:0C:82:44:2D:3A in vlan 90 is moving from port Gi5/1 to port Gi5/2
*Jun 12 07:33:48: %C4K_EBM-4-HOSTFLAPPING: Host 54:26:96:0E:F4:10 in vlan 90 is moving from port Po10 to port Gi5/4
*Jun 12 07:34:09: %C4K_EBM-4-HOSTFLAPPING: Host 54:26:96:0E:F4:10 in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:34:34: %C4K_EBM-4-HOSTFLAPPING: Host 54:26:96:0E:F4:10 in vlan 90 is moving from port Gi5/2 to port Gi6/1
*Jun 12 07:36:50: %C4K_EBM-4-HOSTFLAPPING: Host 90:18:7C:66:0A:8D in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:39:14: %C4K_EBM-4-HOSTFLAPPING: Host 1C:B0:94:B3:A0:8A in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:39:36: %C4K_EBM-4-HOSTFLAPPING: Host 20:02:AF:62:78:DD in vlan 90 is moving from port Gi5/2 to port Gi5/1
*Jun 12 07:39:37: %C4K_EBM-4-HOSTFLAPPING: Host 4C:8D:79:D4:81:48 in vlan 90 is moving from port Gi5/2 to port Gi5/1
*Jun 12 07:40:09: %C4K_EBM-4-HOSTFLAPPING: Host 70:72:3C:B9:CE:F7 in vlan 90 is moving from port Gi5/2 to port Gi5/1
*Jun 12 07:40:22: %C4K_EBM-4-HOSTFLAPPING: Host 68:09:27:9E:50:DD in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:40:34: %C4K_EBM-4-HOSTFLAPPING: Host 68:09:27:9E:50:DD in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:41:02: %C4K_EBM-4-HOSTFLAPPING: Host 68:09:27:9E:50:DD in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:41:20: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:42:43: %C4K_EBM-4-HOSTFLAPPING: Host 68:09:27:9E:50:DD in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:43:27: %C4K_EBM-4-HOSTFLAPPING: Host 00:21:6B:85:6C:7C in vlan 80 is moving from port Gi5/3 to port Gi5/4
*Jun 12 07:43:28: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:82:3B:03:DF in vlan 80 is moving from port Gi5/2 to port Gi5/3
*Jun 12 07:43:32: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:82:3B:03:DF in vlan 80 is moving from port Gi5/3 to port Po10
*Jun 12 07:43:35: %C4K_EBM-4-HOSTFLAPPING: Host A0:88:B4:CE:AD:04 in vlan 80 is moving from port Po10 to port Gi5/3
*Jun 12 07:43:41: %C4K_EBM-4-HOSTFLAPPING: Host 68:09:27:9E:50:DD in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:44:01: %C4K_EBM-4-HOSTFLAPPING: Host 68:09:27:9E:50:DD in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:44:08: %C4K_EBM-4-HOSTFLAPPING: Host 68:09:27:9E:50:DD in vlan 90 is moving from port Gi5/2 to port Gi6/1
*Jun 12 07:44:57: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:82:3B:03:0A in vlan 80 is moving from port Po10 to port Gi5/4
*Jun 12 07:45:17: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:82:3B:03:0A in vlan 80 is moving from port Gi5/4 to port Gi5/3
*Jun 12 07:45:34: %C4K_EBM-4-HOSTFLAPPING: Host 20:68:9D:D9:B2:48 in vlan 90 is moving from port Gi6/1 to port Gi5/4
*Jun 12 07:45:48: %C4K_EBM-4-HOSTFLAPPING: Host 20:68:9D:D9:B2:48 in vlan 90 is moving from port Gi5/4 to port Po10
--More--                           *Jun 12 07:46:23: %C4K_EBM-4-HOSTFLAPPING: Host 00:26:82:3B:03:0A in vlan 80 is moving from port Gi5/3 to port Gi6/1
*Jun 12 07:46:27: %C4K_EBM-4-HOSTFLAPPING: Host 10:0B:A9:23:15:A4 in vlan 80 is moving from port Gi6/1 to port Gi5/2
*Jun 12 07:48:46: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:50:22: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:50:38: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:51:36: %C4K_EBM-4-HOSTFLAPPING: Host 1C:B0:94:B3:A0:8A in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:51:54: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:52:16: %C4K_EBM-4-HOSTFLAPPING: Host 1C:B0:94:B3:A0:8A in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:52:28: %C4K_EBM-4-HOSTFLAPPING: Host A0:88:B4:CE:A8:60 in vlan 80 is moving from port Gi5/2 to port Po10
*Jun 12 07:52:29: %C4K_EBM-4-HOSTFLAPPING: Host 58:1F:AA:1D:BF:11 in vlan 90 is moving from port Gi6/1 to port Gi5/4
*Jun 12 07:52:38: %C4K_EBM-4-HOSTFLAPPING: Host 58:1F:AA:1D:BF:11 in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:52:57: %C4K_EBM-4-HOSTFLAPPING: Host 1C:B0:94:B3:A0:8A in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:53:49: %C4K_EBM-4-HOSTFLAPPING: Host 1C:B0:94:B3:A0:8A in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:53:58: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:54:31: %C4K_EBM-4-HOSTFLAPPING: Host 1C:B0:94:B3:A0:8A in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:56:17: %C4K_EBM-4-HOSTFLAPPING: Host 1C:B0:94:B3:A0:8A in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 07:57:51: %C4K_EBM-4-HOSTFLAPPING: Host 1C:B0:94:B3:A0:8A in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:57:57: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 07:58:36: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 08:00:40: %C4K_EBM-4-HOSTFLAPPING: Host 1C:B0:94:B3:A0:8A in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 08:00:53: %C4K_EBM-4-HOSTFLAPPING: Host 1C:B0:94:B3:A0:8A in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 08:01:24: %C4K_EBM-4-HOSTFLAPPING: Host 3C:D0:F8:AE:06:47 in vlan 90 is moving from port Po10 to port Gi5/4
*Jun 12 08:01:47: %C4K_EBM-4-HOSTFLAPPING: Host 3C:D0:F8:AE:06:47 in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 08:02:05: %C4K_EBM-4-HOSTFLAPPING: Host 08:3E:8E:70:6E:7B in vlan 80 is moving from port Po10 to port Gi5/4
*Jun 12 08:02:07: %C4K_EBM-4-HOSTFLAPPING: Host EC:85:2F:A7:21:9F in vlan 90 is moving from port Po10 to port Gi5/2
*Jun 12 08:02:11: %C4K_EBM-4-HOSTFLAPPING: Host 08:3E:8E:70:6E:7B in vlan 80 is moving from port Gi5/4 to port Po10
*Jun 12 08:04:07: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 08:04:13: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 08:04:22: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 08:06:00: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/4 to port Gi5/2
*Jun 12 08:06:39: %C4K_EBM-4-HOSTFLAPPING: Host F8:3D:FF:03:E1:AF in vlan 90 is moving from port Gi5/2 to port Gi6/1
*Jun 12 08:06:42: %C4K_EBM-4-HOSTFLAPPING: Host 84:A6:C8:CE:5C:98 in vlan 90 is moving from port Gi5/4 to port Gi5/3
*Jun 12 08:07:32: %SYS-5-CONFIG_I: Configured from console by bunnak.so on vty0 (10.13.2.97)
*Jun 12 08:07:36: %C4K_EBM-4-HOSTFLAPPING: Host 08:11:96:DE:72:8C in vlan 80 is moving from port Gi5/4 to port Po10
*Jun 12 08:08:54: %C4K_EBM-4-HOSTFLAPPING: Host EC:85:2F:A7:21:9F in vlan 90 is moving from port Gi5/2 to port Gi6/1
*Jun 12 08:09:48: %C4K_EBM-4-HOSTFLAPPING: Host 3C:D0:F8:AE:06:47 in vlan 90 is moving from port Gi5/2 to port Gi5/4
*Jun 12 08:09:51: %C4K_EBM-4-HOSTFLAPPING: Host EC:85:2F:A7:21:9F in vlan 90 is moving from port Gi6/1 to port Gi5/2
*Jun 12 08:09:57: %C4K_EBM-4-HOSTFLAPPING: Host 3C:D0:F8:AE:06:47 in vlan 90 is moving from port Gi5/4 to port Po10
*Jun 12 08:10:06: %C4K_EBM-4-HOSTFLAPPING: Host EC:85:2F:A7:21:9F in vlan 90 is moving from port Gi5/2 to port Po10
*Jun 12 08:11:16: %C4K_EBM-4-HOSTFLAPPING: Host 98:0C:82:44:2D:3A in vlan 90 is moving from port Gi5/2 to port Gi5/1
*Jun 12 08:11:17: %SYS-5-CONFIG_I: Configured from console by bunnak.so on vty0 (10.13.2.97)
*Jun 12 08:12:44: %SYS-5-CONFIG_I: Configured from console by bunnak.so on vty0 (10.13.2.97)
*Jun 12 08:15:26: %C4K_EBM-4-HOSTFLAPPING: Host 40:6F:2A:75:A3:FC in vlan 90 is moving from port Gi5/4 to port Gi6/1
--More--                           *Jun 12 08:16:32: %C4K_EBM-4-HOSTFLAPPING: Host 20:02:AF:62:78:DD in vlan 90 is moving from port Gi5/1 to port Gi5/2
.Jun 12 16:40:59: %C4K_EBM-4-HOSTFLAPPING: Host 98:0C:82:44:2D:3A in vlan 90 is moving from port Gi5/1 to port Gi5/2
Jun 12 16:42:31: %C4K_EBM-4-HOSTFLAPPING: Host 58:1F:AA:06:02:60 in vlan 90 is moving from port Gi5/2 to port Gi5/4
Jun 12 16:42:42: %C4K_EBM-4-HOSTFLAPPING: Host C8:6F:1D:8D:B7:E8 in vlan 90 is moving from port Gi5/1 to port Gi5/2
Jun 12 16:42:57: %C4K_EBM-4-HOSTFLAPPING: Host 18:3D:A2:35:39:0C in vlan 90 is moving from port Gi5/2 to port Gi5/3
Jun 12 16:43:29: %C4K_EBM-4-HOSTFLAPPING: Host 58:1F:AA:06:02:60 in vlan 90 is moving from port Gi5/4 to port Gi5/2
Jun 12 16:43:42: %C4K_EBM-4-HOSTFLAPPING: Host 58:1F:AA:06:02:60 in vlan 90 is moving from port Gi5/2 to port Gi5/4
Jun 12 16:43:56: %C4K_EBM-4-HOSTFLAPPING: Host 90:18:7C:6E:35:10 in vlan 90 is moving from port Gi5/4 to port Po10
Jun 12 16:44:23: %C4K_EBM-4-HOSTFLAPPING: Host C8:6F:1D:8D:B7:E8 in vlan 90 is moving from port Gi5/2 to port Gi5/4
Jun 12 16:44:52: %C4K_EBM-4-HOSTFLAPPING: Host 90:18:7C:6E:35:10 in vlan 90 is moving from port Po10 to port Gi5/2
Jun 12 16:45:17: %C4K_EBM-4-HOSTFLAPPING: Host 90:18:7C:6E:35:10 in vlan 90 is moving from port Gi5/2 to port Po10
Jun 12 16:45:42: %C4K_EBM-4-HOSTFLAPPING: Host C8:6F:1D:8D:B7:E8 in vlan 90 is moving from port Gi5/4 to port Gi5/1
Jun 12 16:46:06: %C4K_EBM-4-HOSTFLAPPING: Host 90:18:7C:6E:35:10 in vlan 90 is moving from port Po10 to port Gi5/4
Jun 12 16:46:18: %C4K_EBM-4-HOSTFLAPPING: Host 18:3D:A2:35:39:0C in vlan 90 is moving from port Gi5/3 to port Gi5/1
Jun 12 16:46:36: %C4K_EBM-4-HOSTFLAPPING: Host 08:11:96:DE:72:8C in vlan 80 is moving from port Po10 to port Gi5/4
Jun 12 16:46:58: %C4K_EBM-4-HOSTFLAPPING: Host 08:11:96:DE:72:8C in vlan 80 is moving from port Gi5/4 to port Po10
Jun 12 16:47:03: %C4K_EBM-4-HOSTFLAPPING: Host 08:11:96:DE:72:8C in vlan 80 is moving from port Po10 to port Gi6/1
Jun 12 16:47:17: %C4K_EBM-4-HOSTFLAPPING: Host 20:02:AF:62:78:DD in vlan 90 is moving from port Gi5/2 to port Gi5/1
Jun 12 16:52:07: %SYS-5-CONFIG_I: Configured from console by shwan.aziz on vty1 (10.13.10.240)
Jun 12 18:02:41: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 8 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Po10 in vlan 2
Jun 12 23:28:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/23, changed state to down
Jun 12 23:28:46: %LINK-3-UPDOWN: Interface GigabitEthernet4/23, changed state to down
Jun 12 23:28:50: %LINK-3-UPDOWN: Interface GigabitEthernet4/23, changed state to up
Jun 12 23:28:51: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/23, changed state to up
Jun 12 23:29:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/23, changed state to down
Jun 12 23:29:35: %LINK-3-UPDOWN: Interface GigabitEthernet4/23, changed state to down
Jun 12 23:29:39: %LINK-3-UPDOWN: Interface GigabitEthernet4/23, changed state to up
Jun 12 23:29:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/23, changed state to up
Jun 12 23:30:21: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/23, changed state to down
Jun 12 23:30:22: %LINK-3-UPDOWN: Interface GigabitEthernet4/23, changed state to down
Jun 12 23:30:25: %LINK-3-UPDOWN: Interface GigabitEthernet4/23, changed state to up
Jun 12 23:30:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/23, changed state to up
Jun 13 03:18:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/33, changed state to down
Jun 13 03:19:00: %LINK-3-UPDOWN: Interface GigabitEthernet4/33, changed state to down
Jun 13 03:19:04: %LINK-3-UPDOWN: Interface GigabitEthernet4/33, changed state to up
Jun 13 03:19:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/33, changed state to up
Jun 13 03:20:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/33, changed state to down
Jun 13 03:20:21: %LINK-3-UPDOWN: Interface GigabitEthernet4/33, changed state to down
Jun 13 03:20:45: %LINK-3-UPDOWN: Interface GigabitEthernet4/33, changed state to up
Jun 13 03:20:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/33, changed state to up
Jun 13 10:52:26: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 6864 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Po10 in vlan 2
Jun 13 11:44:38: %C4K_EBM-4-HOSTFLAPPING: Host 70:72:3C:B9:CE:F7 in vlan 90 is moving from port Gi5/2 to port Gi5/1
Jun 13 11:46:46: %C4K_EBM-4-HOSTFLAPPING: Host A0:88:B4:CE:A8:50 in vlan 80 is moving from port Po10 to port Gi5/3
Actually I'm suspecting that the STP Processes are part of causing CPU Utilization
Ibrahim
