Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco C8300-2N2S-6T
Robert Plunkett
Level 2
Level 2
Good evening, I installed a C-NIM-4X card into a Cisco C8300-2N2S-6T router, when I looked at the status is said "booting" and I can't access it.
Can someone help with getting this card becoming active please?
Hello @kniederberger,
based on your output it seems that you inserted the C-NIM-4X module into the C-SM-NIM-ADPT carrier card. This does not work.
The C-NIM-4X module is supported only for operation in the embedded NIM slots.
This is a known limitation mentioned in the corresponding data sheet for these modules (look at the installation section):
https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/catalyst-8000-series-gigabit-ethernet-lan-wan-modules-ds.html#Modulefeaturecomparison
So you need to swap your NIM-modules accordingly and then all modules should come up.
HTH!
12 Replies 12
Mark Elsen
  - Attach a console to the router and scrutinize the complete boot process ?
 - https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/catalyst-8000-series-gigabit-ethernet-lan-wan-modules-ds.html , look at Table 4 and report back
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you Marce 1000, I tried another module out of the box, and even on a different router, and they both produced the same result.
                         - Take care as  other posted , to install the minimum IOS version required , 17.11.1
 Ref : https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/catalyst-8000-series-gigabit-ethernet-lan-wan-modules-ds.html    Table 1
Min. required IOS Version
17.11.1
17.11.1
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Minimum required IOS version: 17.11.1
Regards, LG
*** Please Rate All Helpful Responses ***
kniederberger
Frequent Visitor
Frequent Visitor
I have the same problem and am running 17.12.04 on a C8300-1N1S-4T2X.
spa in 1/1, still booting
%SPA_OIR-6-OFFLINECARD: SPA (C-NIM-4X) offline in subslot 1/1
Any help would be appreciated!
Sh Platform -- 1/1 C-NIM-4X booting 00:03:35
Hello
please review here  and let us know how you get on?
Kind Regards
Paul
Hi Paul. Was this response to me and if so, which commands did you want output from? Thanks.
RIV-C8300#hw-module session 1/1 endpoint 0
Establishing session connect to subslot 1/1
To exit, type ^a^q
picocom v3.1
port is : /dev/ttyADPT_NIM1
flowcontrol : none
baudrate is : 9600
parity is : none
databits are : 8
stopbits are : 1
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
hangup is : no
nolock is : yes
send_cmd is : sz -vv
receive_cmd is : rz -vv -E
imap is :
omap is :
emap is : crcrlf,delbs,
logfile is : none
initstring : none
exit_after is : not set
exit is : no
Type [C-a] [C-h] to see available commands
Terminal ready
Terminating...
Skipping tty reset...
Thanks for using picocom
RIV-C8300#show facility-alarm status
System Totals Critical: 1 Major: 1 Minor: 0
Source Time Severity Description [Index]
POE Bay 0 Jun 03 2025 09:33:08 INFO Power Over Ethernet Module Missing [0]
POE Bay 1 Jun 03 2025 09:33:08 INFO Power Over Ethernet Module Missing [0]
GigabitEthernet0/0/0 Jun 03 2025 09:33:27 CRITICAL Physical Port Link Down [1]
GigabitEthernet0/0/1 Jun 03 2025 09:33:25 INFO Physical Port Administrative State Down [2]
GigabitEthernet0/0/2 Jun 03 2025 09:33:25 INFO Physical Port Administrative State Down [2]
GigabitEthernet0/0/3 Jun 03 2025 09:33:25 INFO Physical Port Administrative State Down [2]
xcvr container 0/0/5 Jun 03 2025 09:33:25 INFO Transceiver Missing [0]
xcvr container 1/0/0 Jun 03 2025 09:34:04 INFO Transceiver Missing [0]
NIM subslot 1/1 Jun 03 2025 09:33:24 MAJOR Boot state [1]
RIV-C8300#sh hw-module subslot all oir
Module Model Operational Status
subslot 0/0 4x1G-2xSFP+ ok
subslot 0/1 C-NIM-1X ok
subslot 1/0 C-NIM-1X ok
subslot 1/1 C-NIM-4X booting
HTH!
Hello Jens,
Thanks for pointing that out! I completely missed that in that 21-page document. Unfortunately, this is a live system with a few remote branches connected to it so finding an opportunity to have downtime and re-arrange my interfaces/config will be difficult, but it has to happen. I'll let you know how it works out.
Thanks again!
That was the problem. I was able to schedule some downtime to move the modules around to different slots and re-configure the interfaces. The module is now working correctly. Thanks again!
Glad to hear its working now. So please mark my above post as 'solution' so that this topic gets marked as solved. Thanks!
   - @Jens Albrecht                  Done ! (Marked as a solution)  => Tips always appreciated (LOL!)
   M.
       Beauty and terror
      Just keep going
       No feeling is final
